epcs_signature_read_fail_error
Sorry for the delay as quite packed. Based on the checking with internal team. It seems this type of error happen because the NIOSII flash programmer is end of life (EOL).
We recommend that using Quartus Programmer + JIC to program the flash. Can see the link below.
https://www.intel.com/content/www/us/en/docs/programmable/683689/current/programming-96050.html
Thank you.
Fathulnaim
hi ,
thanks for your response.
the reason for checking this is we are upgrading the design from 13.1 to 22.1 . In 13.1 design, we have used cyclone iii and now we are upgrading the device to cyclone v gx device in 22.1.
In 13.1 design , we have used flash file as programming files.
from what you have said, we cant use flash files as programming file as flash programmer is EOL.
So we need to adapt the jic file programming format.
is there any other way to use flash file format?
- SERMASWATHIKA2 years ago
Contributor
hi,
i have tried to generate .jic file also but i am getting error as address overlap
can you please give solution for this.
