EDS 20.1.1.720 installation does not have Eclipse
Greetings,
I installed Quartus II 20.1.1.720 then installed EDS later on.
Embedded_Command_Shell.bat does not work:
PS G:\intel\FPGA\Lite\20.1.1.720\embedded> ./Embedded_Command_Shell.bat
The system cannot find the path specified.
embedded_command_shell.sh brings up an embedded command shell but eclipse cannot be found:
Intel FPGA Embedded Command Shell
Version 20.1 [Build 711]
MINGW64 /g/intel/FPGA/Lite/20.1.1.720/embedded
$ eclipse
bash: eclipse: command not found
Did I miss something?
phiho
- phiho
P.S: After manually running "20.1.1.720\embedded\cygwin_setup\soceds-cygwin-setup.bat", I can start "20.1.1.720\embedded\Embedded_Command_Shell.bat" but there is still no "eclipse".
- phiho
PPS: The title should read : SoCEDSSetup-20.1.0.711-windows installation does not have Eclipse
- BoonBengT_Altera
Moderator
Hi @phiho,
Thank you for posting in Intel community forum, hope this message find you well and apologies for the delayed in response.
I believe that you have followed the steps by installing the SOC EDS in your window machine here, and it is completed successfully.As the following would be running the tool as stated here, please do let us know in which steps are you stuck at for us to better understand the situation.
Warm regards.
BB
