EDS 20.1.1.720 installation does not have Eclipse
P.S: After manually running "20.1.1.720\embedded\cygwin_setup\soceds-cygwin-setup.bat", I can start "20.1.1.720\embedded\Embedded_Command_Shell.bat" but there is still no "eclipse".
- phiho5 years ago
PPS: The title should read : SoCEDSSetup-20.1.0.711-windows installation does not have Eclipse
- BoonBengT_Altera5 years ago
Moderator
Hi @phiho,
Thank you for posting in Intel community forum, hope this message find you well and apologies for the delayed in response.
I believe that you have followed the steps by installing the SOC EDS in your window machine here, and it is completed successfully.As the following would be running the tool as stated here, please do let us know in which steps are you stuck at for us to better understand the situation.
Warm regards.
BB- BoonBengT_Altera5 years ago
Moderator
Hi @phiho,
Good day, by any chances did you managed to try out the steps mentions? Please do let us know if you are still having the difficulties faced.
Warm regards
BB
