20 years agoeCos and Instruction Set Simulator
I investigate if eCos on Nios could answer my needs.
However, I do my tests at home, where I haven't any hardware. Is it possible to make a small application and to run it on the Instruction Set Simulator ? When I try "Run as...", I get : | An internal error occurred during: "Launching". | java.lang.NullPointerException | ... | org.eclipse.core.internal.jobs.Worker.run(Worker.java:66) Thanks, -- Fred4 Replies
I also need to test eCos on Nios and have no hardware. So I need to run it as Simulation. Find below what I did so far. I followed the tutorial which comes with eCOS installation and Step 1 ====== I created the eCos library and then I built it successfully Step 2 ====== I built the application from SDK shell with make INSTALL_DIR=/cygdrive/e/altera/eCOS/test00_install It produces some warning related to some command line options valid for C++ only, not for C. Anyway it seems to work. Step 3 ====== Run IDE File-> New->Project Select: Alera NiosII->Advanced C/C++ Project, => Next Name= ecos_hello unselect 'UseDefaultLocation' checkbox Location= E:\altera\eCOS => Next select 'Make Builder' tab unselect 'use default', Build command= make INSTALL_DIR=/cygdrive/e/altera/eCOS/test00_install => Finish I select 'ecos_hello' project Project->Build Project Console msg: "make INSTALL_DIR=/cygdrive/e/altera/eCOS/prova00_install all make: *** No rule to make target `all'. Stop." http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif Or should I skip the build process? Thanx. --- Quote Start --- originally posted by frd66@Jun 6 2006, 10:28 PM i investigate if ecos on nios could answer my needs.however, i do my tests at home, where i haven't any hardware.
is it possible to make a small application and to run it on the instruction set simulator ?
when i try "run as...", i get :
| an internal error occurred during: "launching".
| java.lang.nullpointerexception
| org.eclipse.core.internal.jobs.worker.run(worker.java:66)
thanks,
-- fred
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15976)
--- quote end ---
--- Quote End ---
Sorry, I forgot to say that I'm using IDE version 5.1.
Do the examples provided with the package run as simulation (inside IDE, when there's no hardware)?????????????? Thanx. --- Quote Start --- originally posted by a_fischetti+jun 9 2006, 12:43 pm--><div class='quotetop'>quote (a_fischetti @ jun 9 2006, 12:43 pm)</div>--- quote start ---
hi,
i also need to test ecos on nios and have no hardware. so i need to run it as simulation.
find below what i did so far.
i followed the tutorial which comes with ecos installation and
step 1
<!--quotebegin-frd66@Jun 6 2006, 10:28 PM i investigate if ecos on nios could answer my needs.
thanks,
-- fred
--- quote end ---
--- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16060)</div> [/b] --- Quote End ---
--- Quote Start --- originally posted by a_fischetti@Jun 9 2006, 06:43 AM hi,i also need to test ecos on nios and have no hardware. so i need to run it as simulation.
step 1
i created the ecos library and then i built it successfully
step 2
i built the application from sdk shell with
make install_dir=/cygdrive/e/altera/ecos/test00_install
it produces some warning related to some command line options valid for c++ only, not for c.
anyway it seems to work.
step 3
run ide
file-> new->project
select: alera niosii->advanced c/c++ project, => next
name= ecos_hello
unselect 'usedefaultlocation' checkbox
location= e:\altera\ecos => next
select 'make builder' tab
build command= make install_dir=/cygdrive/e/altera/ecos/test00_install
=> finish
i select 'ecos_hello' project
project->build project
console msg:
"make install_dir=/cygdrive/e/altera/ecos/prova00_install all
make: *** no rule to make target `all'. stop."
http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/mad.gif
or should i skip the build process?
thanx.
--- quote start ---
originally posted by frd66@jun 6 2006, 10:28 pm
I investigate if eCos on Nios could answer my needs. However, I do my tests at home, where I haven't any hardware. Is it possible to make a small application and to run it on the Instruction Set Simulator ? When I try "Run as...", I get : | An internal error occurred during: "Launching". | java.lang.NullPointerException | ... | org.eclipse.core.internal.jobs.Worker.run(Worker.java:66) Thanks, -- Fred <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15976) --- Quote End --- [/b] --- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16060)</div> [/b] --- Quote End --- I'm afraid you're skiing off piste, the eCos port was only ever run and tested on real hardware. I'm afraid you're the first to try it in the simulator, so I won't at all be surprised if you run into problems. I suspect by far the path of least resistance would be to get a board.
TO_BE_DONE
