20 years agoeCos and Instruction Set Simulator
I investigate if eCos on Nios could answer my needs. However, I do my tests at home, where I haven't any hardware. Is it possible to make a small application and to run it on the Instruction...
20 years agoSorry, I forgot to say that I'm using IDE version 5.1.
Do the examples provided with the package run as simulation (inside IDE, when there's no hardware)?????????????? Thanx. --- Quote Start --- originally posted by a_fischetti+jun 9 2006, 12:43 pm--><div class='quotetop'>quote (a_fischetti @ jun 9 2006, 12:43 pm)</div>--- quote start ---
hi,
i also need to test ecos on nios and have no hardware. so i need to run it as simulation.
find below what i did so far.
i followed the tutorial which comes with ecos installation and
step 1
<!--quotebegin-frd66@Jun 6 2006, 10:28 PM i investigate if ecos on nios could answer my needs.
however, i do my tests at home, where i haven't any hardware.
is it possible to make a small application and to run it on the instruction set simulator ?
when i try "run as...", i get :
| an internal error occurred during: "launching".
| java.lang.nullpointerexception
| org.eclipse.core.internal.jobs.worker.run(worker.java:66)
thanks,
-- fred
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15976)
--- quote end ---
--- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16060)</div> [/b] --- Quote End ---
