Antoniogenn
2 years agoEclipse error when trying to run Nios II program from sdram
Good evening, i have this problem where i try to run the "hello world" template in Eclipse after having designed a nios II system in Platform Designer configured with the sdram as the exception and r...
- 2 years ago
It is not wrong.
You may check on this similar previous case -
Probably can help you out. On the reply also got one design that you can try. Hope this will work on your side
Thank you.
Fathulnaim
Antoniogenn
2 years agoThank you, but i have already tried that design and it works, but when i try to replicate it from the ground up (the exact same design) it no longer works, i'm trying to figure out why
