Antoniogenn
2 years agoEclipse error when trying to run Nios II program from sdram
Good evening, i have this problem where i try to run the "hello world" template in Eclipse after having designed a nios II system in Platform Designer configured with the sdram as the exception and r...
- 2 years ago
It is not wrong.
You may check on this similar previous case -
Probably can help you out. On the reply also got one design that you can try. Hope this will work on your side
Thank you.
Fathulnaim
Antoniogenn
2 years agoI set the clock as an input for the PLL only and then I used the PLL clock outputs for the rest of the system. Is it wrong?
