Antoniogenn
2 years agoEclipse error when trying to run Nios II program from sdram
Good evening, i have this problem where i try to run the "hello world" template in Eclipse after having designed a nios II system in Platform Designer configured with the sdram as the exception and r...
- 2 years ago
It is not wrong.
You may check on this similar previous case -
Probably can help you out. On the reply also got one design that you can try. Hope this will work on your side
Thank you.
Fathulnaim
wwanalim_intel
Contributor
2 years agoHi,
Greetings and welcome to Intel's forum.
Please give me some time to check on this issue and will get back to you with the update.
Thank you.
Fathulnaim
