Oliver_I_Sedlacek
Contributor
2 years agoEclipse crashing whilst connected to target
As per title, after running for a few minutes my Eclipse hangs quite consistently. When I close I get this exception report: Anyone seen this, got any work arounds?
tehjingy_Altera
2 years agoHi Oliver
Just to ask, when you are debugging with the Eclipse.
Are you running the juart-terminal together?
If yes, could you try closing the juart-terminal before start debugging.
After flashing the board and attached the debugger only you open the juart-terminal.
Jingyang, Teh
