16 years agoDownload image ok, but boot fail
Hi Guys, I need help... maybe someone have passed for this trouble. I try to run Linux on Nios II, obviously. My project is based on DE2_NET. Now I used a CYCLONE II EP2C8F256C8 in a cu...
16 years agoIf I download the Linux image via "nios2-download" command line, the result is:
[NiosII EDS]$ nios2-download -g zImage.initramfs.gz Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloaded 3655KB in 2.2s (1661.3KB/s) Verified OK starting processor at address 0xc2500000 assertion "m_state == STATE_DEBUG" failed: file "nios2debug.cpp", line 538 5 [sig] nios2-gdb-server 3532 c:\altera\90\nios2eds\bin\nios2-gdb-server.e xe: *** fatal error - called with threadlist_ix -1 /cygdrive/c/altera/90/nios2eds/bin/nios2-download: line 594: 3532 Hangup nios2-gdb-server --go --tcpport none --write-pid ./nios2-download.pid ./zImage.initramfs.gz.srec
