16 years agoDownload image ok, but boot fail
Hi Guys, I need help... maybe someone have passed for this trouble. I try to run Linux on Nios II, obviously. My project is based on DE2_NET. Now I used a CYCLONE II EP2C8F256C8 in a cu...
16 years ago --- Quote Start --- did you checked your cpu reset vector ? does it point on your EPCS at the correct address ? --- Quote End --- The Reset Vector point to 0x00000000 (ext_flash + offset = 0x0) When I download uCLinux in this SOPC (without MMU) the system ran perfectly. In this case, the Reset vector point to same address. I'll try change for epcs... Thanks
