21 years ago
Does anyone here has you UP3 wrok well?
My development board is UP3 from sls corp.
If I just use the sdram or the sram or the flash, it works very well without any problem.
But if i use them together, that means, a tri_state_bridge is necessary, and I must add a mux to organize the I/O signal, ps: these memory decevices use shared pins. Then the problem comes, i can't run any programme on the board any more.
Does anyone come cross the same problem?
And there is another question: the sdram pins is shared by other device, but the sdram controller use slave port but tri_state slave port, even if you set the controller with "shared dqm/dq/ I/o pins", can it works well?
Thank you!
    Hi:
    the kit work well , you can down the files "sls_sram_16_bit" and "sls_tristate_16x2_character_lcd" from the website of sls corp . I use them and the kit work well
    Which version did you download?
    I have downloaded the "Accessing Memory" design for quartus 4.1 and if I don't modify it but directly download it to the fpga, it will work well. But if I modify a little, everything will changed:( PS: I am using Quartus 4.2.
    Then I downloaded the "Accessing Memory" design for quartus 5.0 , and it still doesn't work anyway.
    Do you just use the reference design or construct the system by yourself using the sls component( lcd & sram)? And what your quartus version is?
    Thank you so much!!
    I use the QII5.0 and sopcbuilder 5.0 ,I use them to design myself project and it works well, So is that. Good luck for you
