21 years agoDoes anyone here has you UP3 wrok well?
My development board is UP3 from sls corp. If I just use the sdram or the sram or the flash, it works very well without any problem. But if i use them tog...
21 years agoWhich version did you download?
I have downloaded the "Accessing Memory" design for quartus 4.1 and if I don't modify it but directly download it to the fpga, it will work well. But if I modify a little, everything will changed:( PS: I am using Quartus 4.2. Then I downloaded the "Accessing Memory" design for quartus 5.0 , and it still doesn't work anyway. Do you just use the reference design or construct the system by yourself using the sls component( lcd & sram)? And what your quartus version is? Thank you so much!!
