20 years agodo I must update to quartus 5.1 + sp2, nios2 5.1
hi:
I use the quartus 5.0 + sp1, nios2 5.0 now. do I must update the tool to quartus 5.1 + sp2, nios2 5.1 + sp1 If I want to use the nios2 linux tool chains? Because if update the quartus tool maybe affect the fpga design previously,it will spend much time to redressal the use logic. please give me some advice ?Thanks a lot!4 Replies
--- Quote Start --- originally posted by alex824@Apr 11 2006, 11:39 AM hi:i use the quartus 5.0 + sp1, nios2 5.0 now.
do i must update the tool to quartus 5.1 + sp2, nios2 5.1 + sp1 if i want to use
because if update the quartus tool maybe affect the fpga design previously,it will
please give me some advice ?thanks a lot!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14217)
--- quote end ---
--- Quote End --- I would recommand you move to the latest tools. start with mininal logic, with only sdram cfi flash, uart and timer. only after you have successful boot, then add more user logic step by step. after you have all the logic, you can use quartusII's "design space explore" to improve speed/area .
Thanks a lot.I will do it.
You should use "svn" to control your hardware projects, too.
It is very helpful during developments. - Altera_Forum
though altera use schematic for their top level fpga design of nios2 kits,
I would suggest you use HDLs (verilog or VHDL) instead. HDLs are easier to use and version control.
