20 years agodo I must update to quartus 5.1 + sp2, nios2 5.1
hi: I use the quartus 5.0 + sp1, nios2 5.0 now. do I must update the tool to quartus 5.1 + sp2, nios2 5.1 + sp1 If I want to use the nios2 linux tool chains? Because if update ...
20 years ago --- Quote Start --- originally posted by alex824@Apr 11 2006, 11:39 AM hi:
i use the quartus 5.0 + sp1, nios2 5.0 now.
do i must update the tool to quartus 5.1 + sp2, nios2 5.1 + sp1 if i want to use
because if update the quartus tool maybe affect the fpga design previously,it will
spend much time to redressal the use logic.
please give me some advice ?thanks a lot!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14217)
--- quote end ---
--- Quote End --- I would recommand you move to the latest tools. start with mininal logic, with only sdram cfi flash, uart and timer. only after you have successful boot, then add more user logic step by step. after you have all the logic, you can use quartusII's "design space explore" to improve speed/area .
