20 years agoDMA and Uart
hi !
i would like to start implement DMA controller with uart I already generate and download my system into fpga startix II dev board succefully . I saw also documents about DMA , bit into status and control register . To increase performances in my application i would like to use DMA with uart . In this case i need transaction between Ram to uart and vicerversa, try to image a communication RS485 . My fpga will be a master of RS485 com. and then send data from ram to uart , and receive data from uart to ram . When interrupt end transaction occur i process buffer in I would like to know wich important steps i have to follow thanks walter13 Replies
what i have to do ?
create a system multiprocessor , where one cpu works for the communication . Otherwise the dma is a avalon master like a cpu . If i use one cpu for logical processing and an other cpu for the communication i should resolve my problems . Anyway if i choose this system , may i share variables for two cpu? for example with the cpu n°1 i get and send data and put them in memory with name (struct mydata), and with cpu n°2 that i use for logical processing may i read and write the same variable (struct mydata) ? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif - Altera_Forum
ok i found an old post about dma -> uart
i copy and paste and now run successfull , better then nothing ciao walter - Altera_Forum
--- Quote Start --- originally posted by pmicro@Jun 22 2006, 12:50 AM anyway if i choose this system , may i share variables for two cpu?for example with the cpu n°1 i get and send data and
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16325)
--- quote end ---
--- Quote End --- Yes, in general you can share data among different CPUs. There are different ways to do that. I typically use the one we developed for ERIKA Enterprise, it is quite simple because it allows you to share data structures without changing the source code using them... bye Paolo
