20 years agoDMA and Uart
hi ! i would like to start implement DMA controller with uart I already generate and download my system into fpga startix II dev board succefully . I saw also documents about DMA , bit into...
20 years ago --- Quote Start --- originally posted by pmicro@Jun 22 2006, 12:50 AM anyway if i choose this system , may i share variables for two cpu?
for example with the cpu n°1 i get and send data and
put them in memory with name (struct mydata), and with cpu n°2 that i use for logical processing may i read and write the same variable (struct mydata) ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16325)
--- quote end ---
--- Quote End --- Yes, in general you can share data among different CPUs. There are different ways to do that. I typically use the one we developed for ERIKA Enterprise, it is quite simple because it allows you to share data structures without changing the source code using them... bye Paolo
