DK-DEV-AGI027-RA: JTAG chain broken after Nios V Hello, FPGA recovery fails
Hi
Can you provide more details regarding the Nios V Hello tutorial modifications, including the SmartVID changes? The issue seems to imply that either the FPGA was damaged or is not being powered to its required core voltage.
- NIJGNAS8 months ago
Sure. I followed the DK-DEV-AGI027-RA dev kit documentation and only changed the configuration scheme, SmartVID (PMBus) related settings, and the clock/reset pin constraints when porting the Nios V Hello design.
I am attaching screenshots of:
- Device and Pin Options - Configuration
- Configuration Pin Options
- Device and Pin Options - Power Management and VID
1) Device and Pin Options settings
Section Setting Value Configuration Configuration scheme AVST x8 Configuration VID mode of operation PMBus Master Configuration Pin Options USE PWRMGT_SCL output Enabled, SDM_IO0 Configuration Pin Options USE PWRMGT_SDA output Enabled, SDM_IO12 Configuration Pin Options USE CONF_DONE output Enabled, SDM_IO16 Configuration Pin Options Other pins (PWRMGT_ALERT, INIT_DONE, etc.) Not enabled Power Management and VID Bus speed mode 100 KHz Power Management and VID Slave device type Other Power Management and VID Number of slave devices 1 Power Management and VID PMBus device 0 slave address 47 Power Management and VID Enable PAGE command Off (unchecked) 2) Clock and reset constraints used
# Reset
set_location_assignment PIN_D36 -to reset_reset_n
set_instance_assignment -name IO_STANDARD "1.2-V" -to reset_reset_n
# Clock (differential)
set_location_assignment PIN_N45 -to clk_clk
set_location_assignment PIN_L46 -to clk_clk(n)
set_instance_assignment -name IO_STANDARD "True Differential Signaling" -to clk_clk
These settings allowed the design to program successfully and print the "Hello" message once. After that first run, JTAG Auto Detect started failing with the UNKNOWN devices and the same JTAG chain error messages as previously posted.
- SteveK_Arrow8 months ago
Hi
I think it would be interesting to see what happens if the SDM I2C controller is disabled. The SDM controller is responsible for the SmartVID function and the JTAG chain.
Set SW4 [1:4] to OFF/OFF/ON/OFF, where OFF is open and ON is closed. (Table 4 of the Development Kit User Guide)
-duplication-
- BoonBengT_Altera6 months ago
Moderator
Hi NIJGNAS ,
I hope you’re doing well. I wanted to follow up and check if there are any remaining questions or concerns regarding this matter.
Please let us know if anything still needs clarification — we’re happy to assist further.
Thank you for your time, and we look forward to your feedback.
Best Wishes
BB
- BoonBengT_Altera5 months ago
Moderator
Hi NIJGNAS,
Greetings, as we do not receive any further clarification/updates on the matter, hence would assume challenge are overcome. We will continue to monitor this post for the next 5 days. If there are no further inquiries during this period, I will step back and allow the community to assist with any future follow-up questions.
Altera Technical Support
