20 years agoDHCP Client using lwip
I am trying to get DHCP working using LWIP. I have successfully managed to get DHCP working using MicroC but would prefer not to use an OS.
I have downloaded LWIP and have managed to get fixed IP addressing to work but not DHCP client. Does anyone have some sample code to show how this is done ? I am just looking for the intial sequence of function calls to set up the IP address. Do I need to call coarse & fine timer functions to make this work ?2 Replies
--- Quote Start --- originally posted by poirot@Jan 4 2006, 11:22 AM i am trying to get dhcp working using lwip. i have successfully managed to get dhcp working using microc but would prefer not to use an os.i have downloaded lwip and have managed to get fixed ip addressing to work but not dhcp client.
does anyone have some sample code to show how this is done ?
i am just looking for the intial sequence of function calls to set up the ip address. do i need to call coarse & fine timer functions to make this work ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11949)
--- quote end ---
--- Quote End --- Did you set LWIP_DHCP to 1 in lwipopts.h? It's been a while since I worked with the standalone LWIP but I don't recall having a problem with DHCP. Also are you using the lwip_web_server example? Because that has all the code necessary to make DHCP work.
--- Quote Start --- originally posted by bkucera+jan 10 2006, 11:41 am--><div class='quotetop'>quote (bkucera @ jan 10 2006, 11:41 am)</div>--- quote start ---
<!--quotebegin-poirot@Jan 4 2006, 11:22 AM i am trying to get dhcp working using lwip. i have successfully managed to get dhcp working using microc but would prefer not to use an os.
--- quote end ---
--- Quote End --- Did you set LWIP_DHCP to 1 in lwipopts.h? It's been a while since I worked with the standalone LWIP but I don't recall having a problem with DHCP. Also are you using the lwip_web_server example? Because that has all the code necessary to make DHCP work. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=12112)</div> [/b] --- Quote End ---
