20 years agoDHCP Client using lwip
I am trying to get DHCP working using LWIP. I have successfully managed to get DHCP working using MicroC but would prefer not to use an OS. I have downloaded LWIP and have managed to get fixed ...
20 years ago --- Quote Start --- originally posted by bkucera+jan 10 2006, 11:41 am--><div class='quotetop'>quote (bkucera @ jan 10 2006, 11:41 am)</div>
--- quote start ---
<!--quotebegin-poirot@Jan 4 2006, 11:22 AM i am trying to get dhcp working using lwip. i have successfully managed to get dhcp working using microc but would prefer not to use an os.
i have downloaded lwip and have managed to get fixed ip addressing to work but not dhcp client.
does anyone have some sample code to show how this is done ?
i am just looking for the intial sequence of function calls to set up the ip address. do i need to call coarse & fine timer functions to make this work ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11949)
--- quote end ---
--- Quote End --- Did you set LWIP_DHCP to 1 in lwipopts.h? It's been a while since I worked with the standalone LWIP but I don't recall having a problem with DHCP. Also are you using the lwip_web_server example? Because that has all the code necessary to make DHCP work. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=12112)</div> [/b] --- Quote End ---
