design guide for i2c max10 remote system upgrade
Hi @aiedb ,
I'm Joshua, and I will try to help you with this. I suppose you may have seen this link for I2C RSU:
Intel® MAX® 10 FPGA – I2C Remote System Update Design Example
There is a "User Guide" and perhaps the Theory of Operation chapter with specifics on I2C may contain what you're looking for.
Hope this helps.
Joshua.
hii Joshua , i have another question
i was practicing also rsu using nios and uart example , i have build i qsys system of my own based on the rsu_example that i found in the design store
i am practicing on neek kit that have max10d50 which support rsu , i configured the on chip flash ip to dual compressed mode
and also under assignments ->device->device and pin options ->configuration-> i chose dual compressed image the same configuration that i choose in the ip flash core
and in the nios reset vector i choose the generic quad spi controller and on the exception victor i choose on chip ram as same as the example also
but when i compile the design i get an error which doesn't make sense to me i attached a pictures of my configuration and the error that i get , how can i resolve this error i be very glad for help
- JoshuaT_Altera1 year ago
Hi@aiedb ,
Please open a new thread for this query as it's different from the original post.
Joshua.
I saw a similar thread; did this reply help? https://community.intel.com/t5/Nios-V-II-Embedded-Design-Suite/max10-remote-system-update-nios-with-uart/m-p/1687908/highlight/true#M53677
- aiedb1 year ago
yes thanks:)
