Oliver_I_Sedlacek
Contributor
2 years agoDebugger wont connect to NIOS II hello world on Cyclone GX development board
The Cyclone 10GX seems to configure from the programmer but Eclipse fails to connect though the embedded download cable. I only got this far by checking the 'Ignore mismatched system ID' and 'I...
wwanalim_intel
Contributor
2 years agoHi,
Did the previous suggestion which is to connect the debug_reset_request to processor reset port solved the "downloading ELF process failed" error?
Regarding the debugger cannot connect issue, you also can try to remove the SYSID IP in Platform Designer, then Re-Add it again, then recompile everything and re-try. By the way, is the design from an example design downloaded somewhere?
We sent you an email. Hope you can reply to that as we want to help figuring the reason you cannot reply to the below thread.
