19 years agoDE2_WEB (EXT_FLASH_NAME undeclared)
I am a NIOS newbie, tried to build DE2_WEB into NIOS II IDE v6.1. As the terasic provided code was built with v6.0, I regenerated the system in SOPC and recompiled in Quartus II v6.1, Then I tried building the project in NIOS II and I get following errors: ============================================== **** Build of configuration Debug for project web_server_0 **** make -s all Compiling network_utilities.c... ../network_utilities.c: In function `generate_and_store_mac_addr': ../network_utilities.c:196: error: `EXT_FLASH_NAME' undeclared (first use in this function) ../network_utilities.c:196: error: (Each undeclared identifier is reported only once ../network_utilities.c:196: error: for each function it appears in.) ../network_utilities.c: In function `get_board_mac_addr': ../network_utilities.c:225: error: `EXT_FLASH_BASE' undeclared (first use in this function) ../network_utilities.c: In function `FindLastFlashSectorOffset': ../network_utilities.c:358: error: `EXT_FLASH_NAME' undeclared (first use in this function) make: *** [obj/network_utilities.o] Error 1 Build completed in 5.956 seconds ================================================ I checked in "system.h" for flash configuration, it seems fine to me: ================================================ /* * cfi_flash_0 configuration * */ # define CFI_FLASH_0_NAME "/dev/cfi_flash_0"# define CFI_FLASH_0_TYPE "altera_avalon_cfi_flash"# define CFI_FLASH_0_BASE 0x00000000# define CFI_FLASH_0_SPAN 4194304# define CFI_FLASH_0_SETUP_VALUE 40# define CFI_FLASH_0_WAIT_VALUE 160# define CFI_FLASH_0_HOLD_VALUE 40# define CFI_FLASH_0_TIMING_UNITS "ns"# define CFI_FLASH_0_UNIT_MULTIPLIER 1# define CFI_FLASH_0_SIZE 4194304# define CFI_FLASH_0_CONTENTS_INFO "SIMDIR/cfi_flash_0.dat 1130817963"# define ALT_MODULE_CLASS_cfi_flash_0 altera_avalon_cfi_flash ================================================= can anyone please suggest any solution?? Thanks, Mona.3 Replies
I'm not sure what the ext_flash.h is supposed to be, but the rest is all due to a mismatch between what your software is expecting to see for your CFI flash's name. Your hardware defines a CFI flash named "cfi_flash_0". Your software is expecting it to be named "ext_flash".
You should change the software to match your hardware your design has. Cheers, - slacker - Altera_Forum
--- Quote Start --- originally posted by slacker@Mar 25 2007, 02:56 PM i'm not sure what the ext_flash.h is supposed to be, but the rest is all due to a mismatch between what your software is expecting to see for your cfi flash's name. your hardware defines a cfi flash named "cfi_flash_0". your software is expecting it to be named "ext_flash".you should change the software to match your hardware your design has.
cheers,
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22491)
--- quote end ---
--- Quote End --- Hi slacker, Thanks for ur reply. I tried changing the name of Flash, but still the problem persists. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif "./network_utilities.c - ext_flash.h location" problem was there cuz I included the statement -># include "ext_flash.h" just to check if that solves the problem. Now, when i look into the module of the hardware design "system_0", I do not see any signals defined for Flash(cfi_flash_0/ext_flash), are they supposed to be there?? and becuz they are not there I get flash declaration error when I build the project in NIOS II?? (SOPC builder file wud be system_0.ptf in this case) Example: for SRAM signals are: // the_sram_0 SRAM_ADDR_from_the_sram_0, SRAM_CE_N_from_the_sram_0, SRAM_DQ_to_and_from_the_sram_0, SRAM_LB_N_from_the_sram_0, SRAM_OE_N_from_the_sram_0, SRAM_UB_N_from_the_sram_0, SRAM_WE_N_from_the_sram_0, ============================================= my hardware part compiles fine in quartus. Any suggestions?? Thanks, Mona.
system.h is a direct reflection of what your hardware contains (<project>.ptf).
The errors, that you're seeing, are likely due to either a component name mismatch or the lack of a component. Cheers, - slacker
