19 years agoDE2_WEB (EXT_FLASH_NAME undeclared)
Hi, I am a NIOS newbie, tried to build DE2_WEB into NIOS II IDE v6.1. As the terasic provided code was built with v6.0, I regenerated the system in SOPC and recompiled in Quartus II v6.1, ...
19 years ago --- Quote Start --- originally posted by slacker@Mar 25 2007, 02:56 PM i'm not sure what the ext_flash.h is supposed to be, but the rest is all due to a mismatch between what your software is expecting to see for your cfi flash's name. your hardware defines a cfi flash named "cfi_flash_0". your software is expecting it to be named "ext_flash".
you should change the software to match your hardware your design has.
cheers,
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22491)
--- quote end ---
--- Quote End --- Hi slacker, Thanks for ur reply. I tried changing the name of Flash, but still the problem persists. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif "./network_utilities.c - ext_flash.h location" problem was there cuz I included the statement -># include "ext_flash.h" just to check if that solves the problem. Now, when i look into the module of the hardware design "system_0", I do not see any signals defined for Flash(cfi_flash_0/ext_flash), are they supposed to be there?? and becuz they are not there I get flash declaration error when I build the project in NIOS II?? (SOPC builder file wud be system_0.ptf in this case) Example: for SRAM signals are: // the_sram_0 SRAM_ADDR_from_the_sram_0, SRAM_CE_N_from_the_sram_0, SRAM_DQ_to_and_from_the_sram_0, SRAM_LB_N_from_the_sram_0, SRAM_OE_N_from_the_sram_0, SRAM_UB_N_from_the_sram_0, SRAM_WE_N_from_the_sram_0, ============================================= my hardware part compiles fine in quartus. Any suggestions?? Thanks, Mona.
