16 years agoDE2 JTAG_UART terminal_PC communication problem : pausing target proccessor
Hi, I am doing the tutorial creating hello_world for a nios Development Board (niosII Sftw. Developers Handbook - Chap3 Getting started from de command line) Tools 9.1 : nios II EDS -> com...
16 years agoAt first glance the steps you performed are correct
--- Quote Start --- - i can read at sysid module/ the id system and timestamp --- Quote End --- I'm not sure what you mean. I suppose this means that you have verified that a sysid module has actually been inserted in sopc You can try to build the system WITHOUT the sysid module, so you can discriminate between a simple sysid identification problem or a more general system failure --- Quote Start --- - i dont understand WHAT IS syslib (¿old IDE file --- Quote End --- This is what you call hello_world_bsp. So this part is ok
