16 years agoDE2 JTAG_UART terminal_PC communication problem : pausing target proccessor
Hi, I am doing the tutorial creating hello_world for a nios Development Board (niosII Sftw. Developers Handbook - Chap3 Getting started from de command line) Tools 9.1 : nios II EDS -> com...
16 years ago --- Quote Start --- There is some problem between QII 9.1sp1 web edition, Nios EDS 9.1 , and the version of example hello_world? --- Quote End --- The version of example is not relevant. It's rather due to the syslib project. Probably there is some mismatch between the programmed sopc and the one define in syslib. Did you generate the nios system with sopc builder? I'd perform again these steps: - open sopc builder and make sure the system ID peripheral has been included - regenerate the sopc system - update the nios system in Quartus and recompile - create a new Nios IDE project and the associated syslib and build them
