16 years agoDE2 JTAG_UART terminal_PC communication problem : pausing target proccessor
Hi, I am doing the tutorial creating hello_world for a nios Development Board (niosII Sftw. Developers Handbook - Chap3 Getting started from de command line) Tools 9.1 : nios II EDS -> com...
16 years agoHi,
I have tried run hello_world with the graphics environment of BST Tool eclipse. When i execute the last step "Run As -> Nios hardware" there is a error message about target connection: [Target Connection]: Actual system ID not found on target at base address If i run configuration the information about system ID and timestamp is Base address: 0x21208b8 ID:0c7f3727ef Timestamp: 1274776738 JTAG Debugging Information File name: *.jdi System ID Properties actual system id : n/a actual system timestamp :n//a There is some problem between QII 9.1sp1 web edition, Nios EDS 9.1 , and the version of example hello_world? I have a license file for IPS_EMBEDDED that i can set by the QII options , it is need do set also with EDS Nios tool? Thanks in advance
