16 years agoDE2 JTAG_UART terminal_PC communication problem : pausing target proccessor
Hi, I am doing the tutorial creating hello_world for a nios Development Board (niosII Sftw. Developers Handbook - Chap3 Getting started from de command line) Tools 9.1 : nios II EDS -> com...
16 years agoHi,
I have EMBEDDED-IPS license. I have do the next steps: 1- QII->SOPC builder 2-QII->compile 3- ../examples/bsp/hal_default/create-this-bsp 4../examples/app/hello_world/rm Makefile 5../examples/app/hello_word/create-this-app 6 ../standard/nios2-configure-sof --> message ********************************************* Searching for SOF file: in . NiosII_cycloneII_2c35_standard.sof Info: ******************************************************************* Info: Running Quartus II Programmer Info: Command: quartus_pgm --no_banner --mode=jtag -o p;NiosII_cycloneII_2c35_standard.sof Info: Using programming cable "USB-Blaster [USB-0]" Info: Started Programmer operation at Tue May 25 15:30:55 2010 Info: Configuring device index 1 Info: Device 1 contains JTAG ID code 0x020B40DD Info: Configuration succeeded -- 1 device(s) configured Info: Successfully performed operation(s) Info: Ended Programmer operation at Tue May 25 15:30:57 2010 Info: Quartus II Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 62 megabytes Info: Processing ended: Tue May 25 15:30:58 2010 Info: Elapsed time: 00:00:04 Info: Total CPU time (on all processors): 00:00:01 ********************************************************* i dont close the command shell 7..open new command-shell ->$nios2-terminal 8../standard/software-examples/app/hello_world 9../_____________________________________/nios2-download -g hello_world.elf and the ERROR CONTINUE
