19 years agoDe2 board Key0 problem
It seems I can't define Key0, it reset the board every time I press it.
Is it some default function?And which nios2 core should I use??3 Replies
Are you using Verilog, VHDL or Block Diagram?
Verilog Solution (Top level module):
Necessary pin assignments: CLOCK_50 = PIN_N2 KEY[0] = PIN_G26 The code assumes that your SOPC Builder system is called nios_system. Also, you will have to add signals for all the other components in your system. A second option is to make the nios_system the top level module and assign clk = PIN_N2 reset_n = PIN_G26 in the pin assignment editor. As for the choice of processors, you can use any version which meets the needs of your application. I like the economy version for its size and lack of caches, but it can be too slow for some applications. - Blairmodule Top ( CLOCK_50, KEY ); input CLOCK_50; input KEY; nios_system NIOSII ( .clk (CLOCK_50), .reset_n (KEY) ); endmodule - Altera_Forum
Thanks a lot.
I am writing a uc/os-II program running on nios2 core. what I am using is in the directory DE2_demonstrations\SOPC_Builder\Reference_Design\DE2_NIOS In DE2_NIOS.v I find this line Reset_Delay delay1 (.iRST(KEY[0]),.iCLK(CLOCK_50),.oRESET(CPU_RESET)); Perhaps that's the reason,I wonder if I can modify that via SOPC Builder. - Altera_Forum
No, I think that it should work fine. Just that the CPU_RESET signal should go to the reset_n signal of the nios_system, instead of the KEY[0] signal as I previously indicated.
Also, that can not modify this in SOPC Builder, but I can be modify in Quartus II by directly editting the DE2_NIOS.v file. - Blair
