19 years agoDe2 board Key0 problem
It seems I can't define Key0, it reset the board every time I press it. Is it some default function?And which nios2 core should I use??
19 years agoNo, I think that it should work fine. Just that the CPU_RESET signal should go to the reset_n signal of the nios_system, instead of the KEY[0] signal as I previously indicated.
Also, that can not modify this in SOPC Builder, but I can be modify in Quartus II by directly editting the DE2_NIOS.v file. - Blair
