11 years agoDE2-115 wiring Triple-Speed-Ethernet
Hello, I am trying to use the TSE-Mac but I am not sure if my wiring is correct.
I tried to port it from the Altera example (ftp://ftp.altera.com/up/pub/altera_material/14.0/tutorials/de2-115/). The problem is, i am using bdf-File as Top-Level-Entity and all the examples don't. Can someone please have a look at it? My Project: http://itexplorer.de/downloads/de2_115_uclinux.zip With best regards, Jan EDIT: I found two mistakes by myself: i mixed up rx and tx clock and i missed an "not" on mdio_oen. Now i can set up eth0 but can´t ping or get pinged.. :/6 Replies
I would suggest you to refer to the TSE Megacore resource center, from there you may found some useful example that you may refer to:
https://www.altera.com/support/support-resources/intellectual-property/interface-protocols/triple-speed-ethernet/ips-inp-tse.html - Altera_Forum
--- Quote Start --- I would suggest you to refer to the TSE Megacore resource center, from there you may found some useful example that you may refer to: https://www.altera.com/support/support-resources/intellectual-property/interface-protocols/triple-speed-ethernet/ips-inp-tse.html --- Quote End --- Thank you for your reply. In the meantime I figured it out by myself. I had to make some entry's in my .sdc-File. - Altera_Forum
Can you share which entries you had to enter?
--- Quote Start --- Can you share which entries you had to enter? --- Quote End --- I ziped the top.vhd and the SDC-File for you ;) - Altera_Forum
Thanks for sharing. I noticed in your design that you have an MMC and a CFI. Is this where you had the Linux to boot from?
I'm using the MMC for the Root-File-System and the CFI for storing the Kernelimage.
