11 years agoDE2-115 wiring Triple-Speed-Ethernet
Hello, I am trying to use the TSE-Mac but I am not sure if my wiring is correct. I tried to port it from the Altera example (ftp://ftp.altera.com/up/pub/altera_material/14.0/tutorials/de2-115/)...
11 years ago --- Quote Start --- I would suggest you to refer to the TSE Megacore resource center, from there you may found some useful example that you may refer to: https://www.altera.com/support/support-resources/intellectual-property/interface-protocols/triple-speed-ethernet/ips-inp-tse.html --- Quote End --- Thank you for your reply. In the meantime I figured it out by myself. I had to make some entry's in my .sdc-File.
