DE2_115 Board not respond to ping request
I have run the simple_socket_server example on ALtera De2_115 board , though my code run's without any error but wont respond to my ping request from other PC it says Host unreachable. i have attached the print screen of run time console of Eclips.
please help me out where i am wrong... regards kaushal29 Replies
Then I suspect a bug in your software when it recovers RS422 data. Try to run it with the debugger.
I have some updates according to the web server example on the CD. Maybe "kaushal" should look at this example.
Latest System CD: http://www.terasic.com/downloads/cd-rom/de2-115/de2-115_v.1.0.6_systemcd.zip Prerequisites: You MUST use Quartus 10.0 or 10.0sp1. I don't know why, but with 12.1sp1 it doesn't work! The software-part must be the old "Nios II IDE" (nios2-ide) and NOT the new "Nios II Software Build Tools for Eclipse (SBT4E)" (eclipse-nios2). Both are Eclipse-based, but are very different in use! Example project must be on a writeable device and every file must be writable. Project path: DE2_115_demonstrations/DE2_115_Web_Server/DE2_115_WEB_SERVER_RGMII_ENET0 Default IP-address: 192.168.21.171 (can be changed) DHCP-Client enabled! To disable it, Project: web_server_0_syslib (right-click) -> Properties -> System Library -> Software Components... -> NicheStack TCP/IP Stack -> Global Options -> Use DHCP to automatically assign IP address 1) Start Quartus and open Project: DE2_115_WEB_SERVER.qpf Use the Quartus Programmer: Quartus Menu -> Tools -> Programmer Use the prebuild SOF-file: DE2_115_WEB_SERVER.sof If no hardware is found, Hardware Setup -> Currently selected hardware (combobox) Click "Start" 2) Start "Nios II IDE" (nios2-ide). Workspace NOT inside example project path! Import existing project web_server_0: File -> Import -> Altera Nios II -> Existing Nios II IDE project into workspace -> software/web_server_0 -> Finish. Import existing project web_server_0_syslib: File -> Import -> Altera Nios II -> Existing Nios II IDE project into workspace -> software/web_server_0_syslib -> Browse SOPC Builder System PTF File: DE2_115_SOPC.ptf (CPU: cpu) -> Finish. You have now 3 projects in workspace: - altera.components - web_server_0 - web_server_0_syslib 3) Build application: Menu: Project -> Build all 4) Run application: Menu: Run -> Run... -> Nios II Hardware -> New launch configuration (Icon: File with +, on top of Nios II Hardware or C/C++ Local Application) -> Project: Browse -> web_server_0 (Nios II ELF copied automatic) -> Run You will see the IP address on the LCD (16x2). Then you should access the webserver with a browser: http://192.168.21.171 See pictures of website and board - Altera_Forum
Latest System CD: http://www.terasic.com/downloads/cd-rom/de2-115/de2-115_v.1.0.6_systemcd.zip Prerequisites: You MUST use Quartus 10.0 or 10.0sp1. I don't know why, but with 12.1sp1 it doesn't work! The software-part must be the old "Nios II IDE" (nios2-ide) and NOT the new "Nios II Software Build Tools for Eclipse (SBT4E)" (eclipse-nios2). Both are Eclipse-based, but are very different in use! Example project must be on a writeable device and every file must be writable. Project path: DE2_115_demonstrations/DE2_115_Web_Server/DE2_115_WEB_SERVER_RGMII_ENET0 Default IP-address: 192.168.21.171 (can be changed) DHCP-Client enabled! To disable it, Project: web_server_0_syslib (right-click) -> Properties -> System Library -> Software Components... -> NicheStack TCP/IP Stack -> Global Options -> Use DHCP to automatically assign IP address 1) Start Quartus and open Project: DE2_115_WEB_SERVER.qpf Use the Quartus Programmer: Quartus Menu -> Tools -> Programmer Use the prebuild SOF-file: DE2_115_WEB_SERVER.sof If no hardware is found, Hardware Setup -> Currently selected hardware (combobox) Click "Start" 2) Start "Nios II IDE" (nios2-ide). Workspace NOT inside example project path! Import existing project web_server_0: File -> Import -> Altera Nios II -> Existing Nios II IDE project into workspace -> software/web_server_0 -> Finish. Import existing project web_server_0_syslib: File -> Import -> Altera Nios II -> Existing Nios II IDE project into workspace -> software/web_server_0_syslib -> Browse SOPC Builder System PTF File: DE2_115_SOPC.ptf (CPU: cpu) -> Finish. You have now 3 projects in workspace: - altera.components - web_server_0 - web_server_0_syslib 3) Build application: Menu: Project -> Build all 4) Run application: Menu: Run -> Run... -> Nios II Hardware -> New launch configuration (Icon: File with +, on top of Nios II Hardware or C/C++ Local Application) -> Project: Browse -> web_server_0 (Nios II ELF copied automatic) -> Run You will see the IP address on the LCD (16x2). Then you should access the webserver with a browser: http://192.168.21.171 - Altera_Forum
--- Quote Start --- Then I suspect a bug in your software when it recovers RS422 data. Try to run it with the debugger. --- Quote End --- Porting the Project on Altera ESDK (Cyclone-III) board will sorted out Re-Initialization Problem, Still don't know what went wrong. But here again as soon as i receive data from remote Board it stop responding to Ping request, The Sequence which i am following on this Current Project is as follows. 1. Porting the Hardware on ESDK_TX board 2. Porting The Software on NIOS-II 3. Board Respond to Ping Request-OK [ping-test-OK.jpg] 4. Send data from NIOS-RX board to This NIOS-TX board 5. Board Stop Responding to Ping Request [Ping Failed after receiving Data.jpg] 6. Re-porting the Software on ESDK Board (During Porting it Stuck at Auto-Negotiation PASSED) [ Stop At Auto-Negotiation PASSED.jpg] 7. Re-try for Re-porting the Software on ESDK Board(During Porting it Stuck at Auto- Negotiation PASSED) 8. Switch OFF the ESDK Board and Then Switch ON the Board, 9. Re-Porting the Hardware on ESDK board 10. Re-Porting The Software on NIOS-II 11. Again Board Respond to Ping Request-OK [Power OFF and ON then Reporting-HW and SW-Ping OK.jpg] 12. Send data from NIOS-RX board to This NIOS-TX board 13. Board Stop Responding to Ping Request So It Seems that as soon as i receive data from remote Board (ESDK-RX), this board stop responding to ping request, and this situation persist till i switch OFF and then switch ON the board and then follow the same procedure again, even re-porting the software (elf file) won't improve the condation. Regards - Altera_Forum
I post more details about the webserver example. attached is also an image with the current ip-address of the DE2-115-board.
ping request and responses (can be requested before and after a HTTP request... no TCP/IP-stack crashes or timeouts):
nios2-Terminal Output of nios2-ide:$ ping 192.168.21.120 PING 192.168.21.120 (192.168.21.120) 56(84) bytes of data. 64 bytes from 192.168.21.120: icmp_req=1 ttl=64 time=0.340 ms 64 bytes from 192.168.21.120: icmp_req=2 ttl=64 time=0.302 ms 64 bytes from 192.168.21.120: icmp_req=3 ttl=64 time=0.319 ms 64 bytes from 192.168.21.120: icmp_req=4 ttl=64 time=0.320 ms 64 bytes from 192.168.21.120: icmp_req=5 ttl=64 time=0.380 ms 64 bytes from 192.168.21.120: icmp_req=6 ttl=64 time=0.321 ms 64 bytes from 192.168.21.120: icmp_req=7 ttl=64 time=0.319 ms 64 bytes from 192.168.21.120: icmp_req=8 ttl=64 time=0.324 msnios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster ", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 Your Ethernet MAC address is 00:07:ed:ff:d6:87 prepped 1 interface, initializing... INFO : TSE MAC 0 found at address 0x0b442000 INFO : PHY Marvell 88E1111 found at PHY address 0x10 of MAC Group INFO : PHY - Automatically mapped to tse_mac_device INFO : PHY - Restart Auto-Negotiation, checking PHY link... INFO : PHY - Auto-Negotiation PASSED INFO : PHY - Checking link... INFO : PHY - Link established INFO : PHY - Speed = 1000, Duplex = Full OK, x=0, CMD_CONFIG=0x00000000 MAC post-initialization: CMD_CONFIG=0x0400020b RX descriptor chain desc (1 depth) created mctest init called IP address of et1 : 192.168.21.171 Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) Acquired IP address via DHCP client for interface: et1 IP address : 192.168.21.120 Subnet Mask: 255.255.255.0 Gateway : 192.168.21.1 Created "web server" task (Prio: 4) Web Server starting up Acquired IP address via DHCP client for interface: et1 IP address : 192.168.21.120 Subnet Mask: 255.255.255.0 Gateway : 192.168.21.1 Fetching file: /mnt/rozipfs/index.html. Fetching file: /mnt/rozipfs/style.css. Fetching file: /mnt/rozipfs/logo1.png. Fetching file: /mnt/rozipfs/alteraup.png. Fetching file: /mnt/rozipfs/side.jpg. Fetching file: /mnt/rozipfs/400X351_color.jpg. Fetching file: /mnt/rozipfs/D5M_500_01.jpg. Fetching file: /mnt/rozipfs/002_500.jpg. Fetching file: /mnt/rozipfs/ADA-HSMC.jpg. Fetching file: /mnt/rozipfs/001_500.jpg. Fetching file: /mnt/rozipfs/favicon.ico. Fetching file: /mnt/rozipfs/favicon.ico. Acquired IP address via DHCP client for interface: et1 IP address : 192.168.21.120 Subnet Mask: 255.255.255.0 Gateway : 192.168.21.1 Acquired IP address via DHCP client for interface: et1 IP address : 192.168.21.120 Subnet Mask: 255.255.255.0 Gateway : 192.168.21.1 Acquired IP address via DHCP client for interface: et1 IP address : 192.168.21.120 Subnet Mask: 255.255.255.0 Gateway : 192.168.21.1 - Altera_Forum
--- Quote Start --- Then I suspect a bug in your software when it recovers RS422 data. Try to run it with the debugger. --- Quote End --- Porting the Design on Altera ESDK board remoev Re-initilization problem so now i port design on Altera ESDK board. Below is the Code Which i use for reading data from RS422 module. and you are write adding this peace of code create problem. like not responding to ping request once it receive data etc.# define PktSize 640# define PktCount 460 void SSSSimpleSocketServerTask() { unsigned int LPktCount = 0; unsigned int Count = 0; unsigned int DataCount = 0; //--------------------------Receive From RS-422 Port @ 1 mbps------------------------------------------- printf("\n\t\t----Ready to Receive Synchronous Data----\n"); while(1) { Count = 0; LPktCount = 0; edge_capture = 0; do { if(edge_capture) { edge_capture = 0; //Clear Interrupt IOWR_ALTERA_AVALON_PIO_DATA(TEMP_OUT_BASE,1); //Send High to Test Pin TEMP_OUT ImgBuff = IORD_ALTERA_AVALON_PIO_DATA(DATA_BASE); //Read Data from RS422 Port Count++; } if(Count == PktSize) //check end of packet-data { Count = 0; //Point to Start of packet data LPktCount++; //Increment packet Count } IOWR_ALTERA_AVALON_PIO_DATA(TEMP_OUT_BASE,0); //Send LOW to Test Pin TEMP_OUT }while(LPktCount != (PktCount-1)); } } - Altera_Forum
--- Quote Start --- Porting the Design on Altera ESDK board remoev Re-initilization problem so now i port design on Altera ESDK board. Below is the Code Which i use for reading data from RS422 module. and you are write adding this peace of code create problem. like not responding to ping request once it receive data etc. --- Quote End --- What operation system do you use? - Windows XP/Vista/7/8? - Linux? What distribution? What development software do you use? - Quartus? - Nios II IDE (nios2-ide)? - Nios II Software Build Tools for Eclipse SBT4E (eclipse-nios2)? - Other development software? What version of the development software do you use? - 10.x? - 12.x? When you are in debug-mode, in what line it stuck? What are the values of variables like edge_capture, Count, PktSize and LPktCount on initialisation and on first packet arrive? - Altera_Forum
You test every time if edge_capture is set or LPktCount != (PktCount-1) => Busy wait. I'm not use about other tasks, but if your task has highest priority, other tasks (TCP/IP-stack task?) couldn't get CPU time...# define PktSize 640 # define PktCount 460 void SSSSimpleSocketServerTask() { unsigned int LPktCount = 0; unsigned int Count = 0; unsigned int DataCount = 0; printf("\n\t\t----Ready to Receive Synchronous Data----\n"); while (1) { Count = 0; LPktCount = 0; edge_capture = 0; do { if (edge_capture) { edge_capture = 0; // Clear Interrupt IOWR_ALTERA_AVALON_PIO_DATA(TEMP_OUT_BASE, 1); // Send High to Test Pin TEMP_OUT ImgBuff = IORD_ALTERA_AVALON_PIO_DATA(DATA_BASE); // Read Data from RS422 Port Count++; } if (Count == PktSize) { // check end of packet-data Count = 0; // Point to Start of packet data LPktCount++; // Increment packet Count } IOWR_ALTERA_AVALON_PIO_DATA(TEMP_OUT_BASE, 0); // Send LOW to Test Pin TEMP_OUT } while (LPktCount != (PktCount-1)); } - Altera_Forum
Are you sure that your ImgBuff table is big enough? How did you define/allocate it?
I've never used the VIC but are you sure you are using the correct procedure to use it in your software? I think it is a bit different than the regular interrupt system.
