13 years agoDE2_115 Board not respond to ping request
I have run the simple_socket_server example on ALtera De2_115 board , though my code run's without any error but wont respond to my ping request from other PC it says Host unreachable. i have attache...
13 years ago --- Quote Start --- Porting the Design on Altera ESDK board remoev Re-initilization problem so now i port design on Altera ESDK board. Below is the Code Which i use for reading data from RS422 module. and you are write adding this peace of code create problem. like not responding to ping request once it receive data etc. --- Quote End --- What operation system do you use? - Windows XP/Vista/7/8? - Linux? What distribution? What development software do you use? - Quartus? - Nios II IDE (nios2-ide)? - Nios II Software Build Tools for Eclipse SBT4E (eclipse-nios2)? - Other development software? What version of the development software do you use? - 10.x? - 12.x? When you are in debug-mode, in what line it stuck? What are the values of variables like edge_capture, Count, PktSize and LPktCount on initialisation and on first packet arrive?
