13 years agoDE2_115 Board not respond to ping request
I have run the simple_socket_server example on ALtera De2_115 board , though my code run's without any error but wont respond to my ping request from other PC it says Host unreachable. i have attache...
13 years ago --- Quote Start --- Then I suspect a bug in your software when it recovers RS422 data. Try to run it with the debugger. --- Quote End --- Porting the Project on Altera ESDK (Cyclone-III) board will sorted out Re-Initialization Problem, Still don't know what went wrong. But here again as soon as i receive data from remote Board it stop responding to Ping request, The Sequence which i am following on this Current Project is as follows. 1. Porting the Hardware on ESDK_TX board 2. Porting The Software on NIOS-II 3. Board Respond to Ping Request-OK [ping-test-OK.jpg] 4. Send data from NIOS-RX board to This NIOS-TX board 5. Board Stop Responding to Ping Request [Ping Failed after receiving Data.jpg] 6. Re-porting the Software on ESDK Board (During Porting it Stuck at Auto-Negotiation PASSED) [ Stop At Auto-Negotiation PASSED.jpg] 7. Re-try for Re-porting the Software on ESDK Board(During Porting it Stuck at Auto- Negotiation PASSED) 8. Switch OFF the ESDK Board and Then Switch ON the Board, 9. Re-Porting the Hardware on ESDK board 10. Re-Porting The Software on NIOS-II 11. Again Board Respond to Ping Request-OK [Power OFF and ON then Reporting-HW and SW-Ping OK.jpg] 12. Send data from NIOS-RX board to This NIOS-TX board 13. Board Stop Responding to Ping Request So It Seems that as soon as i receive data from remote Board (ESDK-RX), this board stop responding to ping request, and this situation persist till i switch OFF and then switch ON the board and then follow the same procedure again, even re-porting the software (elf file) won't improve the condation. Regards
