ETang2
1 year agoDE10 Lite NIOS V jtag-terminal problem
Hello, i implement a NIOS V processor in a DE10 Lite board. I program it using Ashling Riscfree. In this program i have a count value printed in the terminal each 0.5 s. All works fine except that in...
tehjingy_Altera
1 year agoHI
Do you have an update on this?
You mentioned that the printout is a bit delay, could you check in the BSP Setting the memory region for the JTAG UART is it defined as a Peripheral Region? If not could you change it to a Peripheral Region.
Jingyang, Teh
