ETang2
1 year agoDE10 Lite NIOS V jtag-terminal problem
Hello, i implement a NIOS V processor in a DE10 Lite board. I program it using Ashling Riscfree. In this program i have a count value printed in the terminal each 0.5 s. All works fine except that in...
tehjingy_Altera
1 year agoHi
For the printout in the jtag uart, is the logs appearing all at once?
What is the behavior of the printout? Is the printout constantly printout at a different interval than 0.5?
Jingyang, Teh
- ETang21 year ago
Hi, i'm not sure what you mean by the logs.
The printout seems to be line by line (32 hex values) whereas in the program the printout is value by value. The value printedout seems to be many seconds late (the values are printedout both in the jtag-terminal and in the seven_segment display of the DE10).
If i use the same program running in a NIOS II, the values are printedout one by one at the same time than the seven_segment display.
Eric
