14 years agoDE0-NIOS2 clock speed limit 50MHZ
Hi, have "problem". I have DE0 dev board. When I load NIOS2 to fpga and use 50MHz from on board sorce. It works. When I try to add pll 50MHz - > works. But if I use more then 50MHz (pll ...
14 years agoHi,
I have used all pll types - it does not increase speed. Just give variation fort 10 ish mhz. I have looked at recommendations, same result. What else could increase speed. I use default constrains ( if the is any :) ). Should I apply custom constrains? Sorry I am very new in FPGA design. In reports I see that all slack's are positive, with back up.
