13 years agoDDR Memory IP for Bemicro SDK
The BeMicro board has a quite a few components that aren't instantiated with the accompanying project files. Aside from the SD Card and ethernet, the ddr memory is especially interesting.. at...
13 years agoThe LPDDR on the BeMicro SDK board comes up from time to time, and if you just want to use it on that board, then you can get your hands on an eval license. There's a few threads, and here is one recent one:
http://www.alteraforum.com/forum/showthread.php?t=40737 Regarding the Altera controller, yes it is technically possible to modify it at the VHDL/Verilog level and make it work with LPDDR. But if you just want to use it on the BeMicro SDK board, there's little point in doing that since the free eval license exists.
