13 years agocyclone V static power
We recently designed and built a new PCB with a Cyclone V part on it. The part we used is 5CEFA7U19I7N. We are seeing static power consumption that is around 4x the "typical" amount predic...
13 years ago"Passing window" might explain the issue. Nevertheless, are you sure that are you actually measuring static power? Means: no floating pins, no clocks running, no pins sourcing current to a load or an unintended short?
