17 years ago
Cyclone III Starter Board - build error: * overlaps section *
I have the Cyclone III Starter Board and I want to make a simple NIOS C/C++ application for this board. I chose the template count binary (but other templates also don't work). When I press "build" I get the following errors:
ld: section .rodata  overlaps section .exceptions   count_binary_0 line 0 1254122024054 60
ld: section .rwdata  overlaps section .text   count_binary_0 line 0 1254122024054 61
I think that I maybe use the wrong PTF-File (CIII_NiosII_Small.ptf, 56 KB)...?
What else could be the problem?
stefan__
______
nios: NIOS II Version: 8.0, Build: 214
os: Windows Vista Enterprise
fpga: Cyclone III
______
edit: As I made the following steps it works:
- Set System Library Properties like in this tutorial (http://www.nioswiki.com/cyclone_iii_-_nios_ii_-_starter_board)
- Copy the PTF-File in your current project directory
- remove the write protection from every file (in your current project directory)
    Try a PTF file from another example, I guess the CIII_NiosII_Small doesn't have enough memory to hold your code.
    Alternatively you can also try to compile with optimisations and a small C library to reduce the code size.
