17 years agoCyclone III Starter Board - build error: * overlaps section *
Hi, I have the Cyclone III Starter Board and I want to make a simple NIOS C/C++ application for this board. I chose the template count binary (but other templates also don't work). When I pres...
17 years agoThanks for your response.
--- Quote Start --- Alternatively you can also try to compile with optimisations and a small c library to reduce the code size. --- Quote End --- Yes, this is the same as explained here: http://www.nioswiki.com/cyclone_iii_-_nios_ii_-_starter_board
