GKate1
6 years agoCyclone I read-out external config cfi flash 28F256
HI, I would like to readout external CFI flash connected to cyclone 1 fpga. I have only JTAG connection to fpga, so I need to bypass or bridge through an FPGA. I have installed Quartus lite toolchain. I detect by jtagconfig only device 1PC12 . Is it possible to configure fpga (in RAM) with some loader And run the readout? After reset FPGA might be configured from flash as before...or maybe some better way exists? Thank You
1 Reply
- JohnT_Altera
In order to update the CFI flash then you will need to use https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf. Currently Cyclone 1 FPGA has been EOL so I am sorry to tell you that I am not sure if this IP is suitable for you to update the flash as it is no longer supported.
