21 years agocyclone 1c20f400c7
Hi, I am new to altera FPGA and its NiosII. I got below problems need your great help:
1, I add some pio, uart and spi port in Full_featured example then built it without any errors. 2, In IDE, i tried to run 'hello_world' without any revise but it failed. I was noticed ''verify failed'' after bulding and running the project. I am using quantus II 5.0 and IDE 5.0 also. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif3 Replies
Does your reset address points to volatile memory such as DRAM?
--- Quote Start --- originally posted by james@Jul 18 2005, 04:45 PM does your reset address points to volatile memory such as dram? --- Quote End --- Hi ,James,but what might be the pending result if I make reset address to a volatile memory? - Altera_Forum
the system will not work if your reset is pending
