21 years ago
Custom Component with Master & Slave ports
I'd like to edit a custom component to have both master and slave ports tie to the Avalon Switch Fabric such that it can receive bus transfers from NIOS II and/or initiate bus transfers to access an on-chip RAM built in SOPC Builder.
The slave ports have been tied to the ASF with no problems using:
clock (input)
reset (input)
chip select (input)
write strobe (input)
read strobe (input)
write data bus (input)
read data bus (output)
address bus (input)
interrupt (output)
In the component editor, for it to be a master, these are the signals that seem to be needed:
clk (input)
waitrequest or interrupt (input)
write strobe (output)
read strobe (output)
write data bus (output)
read data bus (input)
address bus (output)
1) From reading about the wait request line, whenever other masters (NIOS II or DMA) are initiating, this line will tell other masters to not initiate any transactions. Say the NIOS II writes an instruction to my custom logic to grab the data from the on-chip memory and send it off-board, would this line be active such that it will prevent my custom logic from functioning?
2) I am only going to access a specific on-chip memory with address range of, say, 0x904000-0x904FFF, what Avalon Switch Fabric signals are needed from the custom logic to read and write to that memory space?
1 Reply
    You can make it as show here:
    CLASS user_logic_Camelot_Ethernet_Monitor
       ASSOCIATED_FILES
          Add_Program = "";
          Edit_Program = "";
          Generator_Program = "mk_user_logic_Camelot_Ethernet_Monitor.pl";
       MODULE_DEFAULTS
          class = "user_logic_Camelot_Ethernet_Monitor";
          class_version = "2.0";
          SYSTEM_BUILDER_INFO
             Instantiate_In_System_Module = "1";
             Is_Enabled = "1";
             Date_Modified = "--unknown--";
          WIZARD_SCRIPT_ARGUMENTS
          PORT_WIRING
          MASTER monitor_avalon_master
                SYSTEM_BUILDER_INFO
        Bus_Type = "avalon";
        Address_Width = "32";
      Max_Address_Width = "32";
      Data_Width = "32";
      Is_Enabled = "1";
                PORT_WIRING
                  PORT clk
                   width = "1";
                   direction = "input";
                   type = "clk";
                  PORT reset
                   width = "1";
                   type = "reset";
                  PORT address
                   width = "32";
                   direction = "output";
                   type = "address";
                  PORT byteenable
                   width = "4";
                   type = "byteenable";
                  PORT read
                   width = "1";
                   type = "read";
                  PORT readdata
                   width = "32";
                   type = "readdata";
                  PORT write
                   width = "1";
                   type = "write";
                  PORT writedata
                   width = "32";
                   type = "writedata";
                  PORT waitrequest
                   width = "1";
                   type = "waitrequest";
          SLAVE monitor_avalon_slave
         SYSTEM_BUILDER_INFO
                    Address_Alignment = "native";
                    Address_Width = "2";
                    Data_Width = "32";
                    Has_IRQ = "1";
                    Has_Base_Address = "1";
                    Read_Wait_States = "0";
                    Write_Wait_States = "0";
                    Setup_Time = "0";
                    Hold_Time = "0";
                    Is_Memory_Device = "0";
                    Uses_Tri_State_Data_Bus = "0";
                    Is_Enabled = "1";
         PORT_WIRING
                  PORT chipselect
                   width = "1";
                   type = "chipselect";
                  PORT saddress
                   width = "2";
                   type = "address";
                  PORT irq
                   width = "1";
                   type = "irq";
                  PORT swrite
                   width = "1";
                   type = "write";
                  PORT swritedata
                   width = "32";
                   type = "writedata";
       USER_INTERFACE
          USER_LABELS
             name = "Camelot_Ethernet_Monitor";
             technology = "Camelot";
       DEFAULT_GENERATOR
          top_module_name = "monitor";
          black_box = "0";
          vhdl_synthesis_files = "";
          verilog_synthesis_files = "monitor.v";
          black_box_files = "";
