11 years agoCustom Avalon MM-Master component that share On-chip memory with CPU
Hello all, I have a simple custom Avalon MM-Master component -- Avalon Master Sample Memory Writer
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity avalon_mem_wri...
11 years agoI have some questions for you both. I am working hard to make my custom instruction read from the on_chip_memory_2. My custom instruction is configured as MM Master. It sometimes read correctly, but sometimes don't.
1) Which transfer mode On_chip_memory_2 by default uses? Fixed Latency? Should I wait for waitrequest os for readdatavalid? Looking at On_chip_memory_2 block diagram on Qsys, I realized that it doesn't have either read, waitrequest or readdatavalid signals. 2) If I try your recommendations to use on_chip_memory_2 second port, how should I access it? With an Avalon MM as well or wiring my component direct to its ports? Thanks, Gustavo
