Correct way to use mSGDMA with a NIOSV/m processor on a MAX10 FPGA
Hi Sue, unfortunately i installed Quartus Prime Pr version 25.3.1 (the latest) and that failed to unravel the PAR file. I will install the version cited to work which was 24.3.1 and try again ! Also the board used is now showing as obsolete as well.
Any idea if there is another ALTERA example design using a NIOSV processor and the mSGDMA IP core i could use ?
Thanks, Dr Barry H
Hello Dr. Barry,
It’s recommended to use the same Quartus Prime version that was originally used for the design. This helps avoid project migration issues that could alter IP behavior and potentially introduce untested or unexpected results.
I was able to extract the file and have compressed it, it’s attached here. Please let me know if you’re able to download it successfully.
Thank you,
Fawaz
- drbarryh8 months ago
Contributor
Hi Fawaz, Thanks for the feedback ....and yes that is always true ....try and use the same Quartus version otherwise mayhem can ensue ! Actually i can't see any attached z compressed zip file here ?
Maybe it was removed by Intel server ?
Thanks, Dr Barry H- tehjingy_Altera8 months ago
