Correct way to use mSGDMA with a NIOSV/m processor on a MAX10 FPGA
Hi Dr. Barry H,
I put the link in my text, but it didn't work! :-(
It also won't let me just paste the link. I don't know why! Paste this link in your brower:
https://www.intel.com/content/www/us/en/design-example/843487/agilex-7-nios-v-m-processor-with-ddr-dma-and-ocm-design-example.html
Sue
Hi drbarryh
The link shared by SueC_Altera is the one you are looking for.
It is using the NiosV processor core with the mSGDMA IP.
It is for the Agilex7 but you could recreate the hardware connections in the project for the device that you want.
Do take note on the naming of the par. It should be top.par and not top(x).par if you have downloaded multiple.
But once you managed to unzip the par, you should go thorugh the IP Upgrade which is prompt when you open the project for the first time.
In the project folder you could see a folder names "sw" in it you could see a main source that you could reference on accesssing the mSGDMA IP from the NiosV processor.
- drbarryh8 months ago
Contributor
HI tehjingy,
Thanks for confirmation. However when i try to open that top.par file in any version of quartus from 24.1 to 25.1 all it ever says it that the template load failed. Can you say which exact version of Quartus to use and what the procedure should be to get that par file to extract into a quartus project please ?
Thanks for your help, Dr Barry H
