Configuring TSE & Nichestack
I have Quartus&SBT 11.1, and a board with PHY 83848.
I cannot bring up the eth interface with simple socket example. SOPC configuration is good (i hope), but i can't initialize the software: Your Ethernet MAC address is 00:07:ed:ff:d7:52 prepped 1 interface, initializing... [tse_mac_init] Error opening TX SGDMA init error -22 on net[0] mctest init called IP address of : 0.0.0.0 DHCP timed out, going back to default IP address(es) With a (long) debug session, i saw that tse_mac_device[maxnets] global variable is not properly setted. How can i add a phy profile?39 Replies
Ok, i'll try without external descriptor_memory, thanks!
Doesn't work.
Maybe i need to set something on clock_crossing_bridge? Currently i havent bursts allowed and FIFO master to slave and viceversa are to default values - Altera_Forum
Nothing, doesn't work even if i left the clock_crossing_bridge and clock all design with ddr clock.
It stucks at that DMA loop But it's correct that dev->descriptor_base is 0? Shoudn't be the address of the main memory? It's always 0 (both with externam descriptor memory or internal) - Altera_Forum
No, the macro TSE_SYSTEM_EXT_MEM_NO_SHARED_FIFO should set it up with the address of your descriptor memory block.
I did it. I checked it many tines. Even eithout external memories and only one memory and clock doesnt work
It stucks at dma loop. It seems a resource conflict. Perphas some priority (irq) has to be set in sopc? - Altera_Forum
No I don't think so. The IRQ number is automatically picked up at the driver instantiation and you would get a compile time error if it wasn't set properly.
You need to trace the TSE driver instantiation and try to understand why it isn't setting dev->descriptor_base properly. - Altera_Forum
Ok, thanks.
Ah, the board that i'm working on it's not a develpoment board, but a custom board - Altera_Forum
Ok, it seems that dev->descriptor_base is referred to a global variable set it up at alt_sys_init.c by calling a macro that it's defined in altera_avalon_sgdma.h:
Plase note that i'm using external descriptor memory. Bold line is descriptor_base and it's not touched in code after this initialization. However, if i put the descritor base inside bold line, it stucks again in dma loop, but dev->descritor_base is now correct. Question: descriptor_base should be the same value for sgdma tx and rx?#define ALTERA_AVALON_SGDMA_INSTANCE(name, dev) static alt_sgdma_dev dev = { ALT_LLIST_ENTRY, name##_NAME, ((void *)(name##_BASE)), ((alt_u32 *) 0x0), \ ((alt_u32) 0x0), ((alt_u32) 0x0), ((alt_sgdma_descriptor *) 0x0), ((alt_sgdma_descriptor *) 0x0), ((void *) 0x0), ((void *) 0x0), ((alt_u16) 0x0) }; - Altera_Forum
I haven't used the TSE driver in a long while, but I believe the proper way to initialize the descriptor memory base is via the TSE_SYSTEM_INT_MEM_NO_SHARED_FIFO and TSE_SYSTEM_EXT_MEM_NO_SHARED_FIFO macros.
AFAIK you don't need to set up different descriptor bases for tx and rx, those are automatically taken care of by the driver that will use different addresses for each DMA. Did you try Signaltap to see what the DMAs are doing? - Altera_Forum
This just make no sense.
In my main vhdl file i'm exporting sysclk.c3 as PHY clock (25 MHz since i'm using MII). If i set the sysclk PLL as normal pll, i get the warning "Critical Warning (176598): PLL "nios:nios_inst|sysclk:the_sysclk|sysclk_altpll_l4h2:sd1|pll7" input clock inclk[0] is not fully compensated because it is fed by a remote clock pin "Pin_F2"" but ethernet works as expected (all timings meeted) If i set the PLL in "no compensation" mode, all timing are meeted but the ethernet stucks at DMA loop
