10 years agoconfiguration problem in programmer
Hello everyone,
I actually have some problem about programming FPGA in programmer. When I connect the FPGA in my Quartus, it detect FPGA and I don't have neither compilation problems I have also done hardware setup and add file But when I press start, the progress is failed immediately. I've checked different voltage in my FPGA connection, like TDI= 3.3V TMS=3.3V TDo= 3.3V TCK=0V it seems it's correct, but when I download the program in FPGA, it seems these voltage don't react (I think TCK, TDI and TDO should react). Could anyone help me. I've spend a lot of time in this problem thanks you very much.4 Replies
do you program sof file to the device? check nconfig signal. if nconfig remain low, fpga remains reset.
thank you for u reply, I've program sof file. How could I check, nconfig signal?
What development board are you using? Your own design or a commercial one?
What programmer are you using? An Altera USB Blaster, or something else? The more info you can provide about your setup (when you ask the question) the better the answer(s) you will get. - Altera_Forum
If you cannot download even sof file, you need to check power, POR(power on reset) condition is different on device. So check relevant power. And I cannot under stand TCK is not toggling, TCK is input from JTAG. The schematic for JTAG is correct?
